FoldersPlus 1.0
FoldersPlus 1.0
Download: http://archive.info-mac.org/cfg/folders-plus.hqx
FoldersPlus is a program that allows easy access to a folder's contents
using a pop-up menu. Drag a folder a FolderPlus window, click on the
folder, and a pop-up menu appears displaying the contents of the folder.
$15 shareware.
