Focus Comatose v4.3- Disk and monitor energy untility
Download: http://archive.info-mac.org/cfg/focus-comatose-43.hqx
Comatose will help you prolong the life of your computer and save on
electricity while doing so!! It allows you to put your computer to
sleep rather than shut down the entire system. It works with all
Macintoshes Plus and later running system 7 or later and only 165K
of memory. Comatose spins down all hard drives on all SCSI buses and
dim the screen to black. The screen blacking allows some monitors to
also power down, adding to electricity savings. Your computer will
run quieter when comatosed and takes a fraction of time to start up
when compared to switching off or shut down. Comatose also has
screen saver capability. You can specify how many minutes before
the screen dims and how many idle minutes before drives spin down.
Your computer will be able to wake up with an incoming phone call,
receive a fax and go back to sleep. Perfect for using that old Mac
sitting in the closet as a stand alone fax!.
Key features:
- Auto Spin down/Screen Off
- Screen Saver & Energy Star Support
- Password protection
- Digital Clock sreen saver (bouncing!)
- Full async. sound playback of sound files of any size!!
- Sound recording capability (using your built-in Mac microphone)
Minimum system configuration of:
* Hardware: Any Macintosh or Power Macintosh (Plus and later).
* System: 7 and higher.
* 165K of free memory.
This update adds support for DOS/Compatibility card. Focus comatose
is $25 shareware. If you decide to continue using
it after the three day trial period, please pay the registration
fee.
This software is shareware and can be distributed as such on with
shareware collections and CD's provided it is not changed in any way.
Please email questions, suggestions, and feature requests to:
http://www.focusworks.com/
