Fine Volume Control Strip
Download: http://archive.info-mac.org/cfg/fine-vol.hqx
This control strip module lets you set the Audio CD volume to some
lower levels than "1" without fiddling with the innacurate slider in
the AppleCD Audio Player.
Web Page:
http://members.tripod.com/~tunnels/mac.html
It is freeware and may be included in any CDs or Archives as long as
the readme is included.
-Ben Hines
