FinderPatch v1.3
FinderPatch v1.3
Download: http://archive.info-mac.org/cfg/finder-patch-13.hqx
FinderPatch v1.3 for Mac OS 8.6
Requirements:
Mac OS 8.6
2 MB of available RAM for installation.
To unstuff this archive StuffIt Expander v5.x or later is needed.
About:
This patch adds to the Finder of Mac OS 8.6 several enhancements:
?Command Keys
T for Trash
B for Restart
0 (zero) for Shutdown
= for About this Computer
?A Quit Finder menu under the Special
menu to quit the active Finder.
?Assigns desired Finder memory which can be chosen with a Pop Up menu.
?A menu item "Quit Finder" under the Special menu for all those who like
to quit the Finder to make more RAM available or for people like me, who
constantly work on
the Finder to improve it's abilities...
?For PowerBooks a Sleep Command key:
` for Sleep
(works also with Sleep complaint Macs like Mactell, PM4400 and many
others.)
?In the About this Computer you will get a new About Picture, 3D style.
This patch adds to the System of Mac OS 8.6 several enhancements:
(FinderPatch needs to be registered for those features)
?The Help Menu Icon is back! Are you tired of the "Help" text in your menu,
taking
valuable space up? System Patch put's the Icon back into the Menu just as it
was before.
?New excellent made Startup screen (MOSS) in 3D for your Mac.
