Extensions Strip 1.9.3
Download: http://archive.info-mac.org/cfg/extensi ... ip-193.hqx
Extensions Strip hosts control strip modules in the most flexible
environment out there. Its theme is "extensions with a global interface"
because of the extra power it gives to modules, especially the Extensions
Strip savvy ones.
1.9.2 is OS 8.6 compatibile.
To download: http://www44.pair.com/ammon/skidperfect/es/links.html
Skidperfect Software
9.May.99 Extensions Strip 1.9.3 & Control Panels Strip 3.3 released!
