Extension Wizard
Extension Wizard
Download: http://archive.info-mac.org/cfg/extension-wizard.hqx
Stop throwing away documents you can't get to open!
Have you ever experienced the problem where you download a document from
the internet, receive one as an e-mail attachment, or copy one from a
network and you just can't get it to open? Moreover, sometimes these
documents will open, but in one of the last applications you'd want them
to...
...well, Extension Wizard is a utility created to help end these
frustrating situations!
For more information, please visit our website at:
