A copy of EmptyTrash v1.0.2 has been uploaded to
. EmptyTrash is a tiny application
that keeps your "trash" empty. It can be set-up as a "startup" and
"shutdown" item, or just kept on the dekstop for direct use. When launched,
it basically empties the trash, and then quits.
