Reply-To: [email protected]
Subject: Info-Mac Digest V14 #116
To: info-mac-list
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Sun, 19 May 96 Volume 14 : Issue 116
[*] AddressConvertor 1.0
[*] BibTeX version 1.03
[*] CDRead 1.0.1
[*] Email Blaster
[*] Font-o-rama! 1.1.1
[*] GifBuilder 0.3.2
[*] GifBuilder 0.3.2 (French)
[*] Insomniac 1.1.0 for PowerBooks
[*] Log Watcher 1.0.0
[*] MacTyping'French 3.4
[*] Mercutio MDEF 1.3b9
[*] Missions of the Reliant v2.0.0 -> v2.0.1 Patch
[*] Missions of the Reliant v2.0.1
[*] Mobius Speedster Fix 1.0
[*] MOON EGG Version 1.0a1
[*] MYM2QIF 2.6
[*] Skat 1.1.2
[*] Stereo "Zorvak Beep"
[*] Sword Dream v1.7 US
[*] TKS Creator List 4/30/96
[*] VersionEdit 2.0
[*] VIRTUAL 3D KALEIDOSCOPE 3.0.0
[*] Wrath of the Aliens
(A) Monitor getting hot
(A) System 7.5.3 update replies
(Q) Internet Assistant
(Q)Removing Termination from drive?
[Q] Netscape - can't "Save As..." Text
[Q] Where's the new FreePPP?
Appleworks files
Auto-restart after crash?
CD-ROM 7.5.3 update overdue?
commercial messages
Commerical Eudora
Convert sound files to Mac sounds
E-mailing dictations / voice mail
IIe->Powermac data conversion
Launcher limitation (Q)
Monitor getting hot
Performa 5300CD & 6300CD
PowerBook Freeze
Spreadsheet (Q)
Zip vs EZ Drives
Gordon Watts, Liam Breck, Igor Livshits, Adam C. Engst
Files for inclusion:
and upload it to:
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V14 #116"
Date: Fri, 17 May 1996 03:16:07 -0700
Subject: [*] AddressConvertor 1.0
This program merges your Eudora Light email address into your Netscape
address book and vice versa.
This preview version does not convert email address grouped together,
such as folders or mailing lists. However, with a sharewhare fee of $3,
another verison will be sent to you supporting this feature.
Kim Le
115 Quail Ln
Lebanon PA 17042
[Archived as /info-mac/comm/inet/mail/address-convertor-10-hc.hqx; 83K]
Date: Fri, 17 May 1996 03:15:17 -0700
Subject: [*] BibTeX version 1.03
It has no known bugs, however, use at your own risk; there is no
warranty.... The only known crashes are from excessively low application
memory partitions. It seems as if 365k is required for 680x0 machines, and
300k for PPC machines. Since by default it's set at the more generous of
these two, if you use a PPC mac, you could lower the application's
partition size.
This version of BibTeX is totally free.
Recent changes:
1.03 Minor changes --- it now gives a message 'BibTeX run complete.'
in the log window, rather than just finishing. Documentation
update. I've fixed the FREF/BNDL problems, so drag'n'drop
really should work now
1.02 Switchable between Big and Small. Uses new memory allocation
scheme from Rick, so temporary memory is used rather than the
system heap. This means the application's given partition can
be much smaller (300k works for me). Added fref 'TEXT' resource
which was missing previously (so drag and drop will work under
all circumstances now).
1.01 Copes with Unix as well as Mac EOL characters
1.0 Original; soon to be distributed with OzTeX 2.0
What is BibTeX ?
BibTeX is the bibliography handling tool related to the TeX/LaTeX
typesetting system (available on almost all conceivable OS platforms).
When a document is typeset with LaTeX, an auxiliary file (with extension
'.aux') is generated. This auxiliary file contains, amongst other things,
a list of references (to books, articles, research reports, web-url's,...)
cited in the original document. BibTeX takes this list, together with the
name of a style file (extension '.bst') and a list of bibliography
databases (extension '.bib') which are also given in the auxiliary file,
and produces a wonderfully formatted list of references which the LaTeX
system subsequently (and automatically) appends to your typeset document.
-- Vince
[Archived as /info-mac/text/tex/bibtex-103.hqx; 580K]
Date: Fri, 17 May 1996 03:16:14 -0700
Subject: [*] CDRead 1.0.1
CDRead slows down the speed of loading file from hard disk (actually
>From anywhere; network volume, MO and CDROM). You can set any data
rate you want. So you can test your CD-ROM base Director and
Quicktime movies easily, and save your time and CD-Recordables
(money).
[Archived as /info-mac/cfg/cd-read-101.hqx; 73K]
Date: Fri, 17 May 1996 03:16:09 -0700
Subject: [*] Email Blaster
Email Blaster is an AppleScript which works with Eudora 2.1.1 or later.
Email Blaster enables you to send a message to a long list of email
addresses using drag and drop and point and click. Email Blaster will also
do some checking of your email list to ensure that addresses are properly
formatted. Email Blaster is great for distributing electronic newsletters.
Gary Stein
Mactivity, Inc.
[email protected]
[Archived as /info-mac/comm/inet/mail/email-blaster-as.hqx; 17K]
Date: Fri, 17 May 1996 03:15:53 -0700
Subject: [*] Font-o-rama! 1.1.1
Font-o-rama! is a font dialog box. It's a drop-in replacement for the
font dialog box or font menus in all the applications you use. With
Font-o-rama! you can see all the fonts on your system at once!
It's better than other font dialog boxes, because it's carefully
designed to be very quick and easy to use. It's better than font menus
for the same reason. If you like using the keyboard, you can quickly
select and set fonts using only the keyboard. If you like the mouse,
you can set any font, size, or style with a single click.
Font-o-rama! is known to work with many common applications, including
Aldus PageMaker 5.0 and 6.0, Microsoft Word 6.0, QuarkXPress 3.3, etc.
It probably works with your application, too.
Changes in 1.1 include the addition of a short font description to the
font selection window.
Requires: System 7.1
Moderators: Font-o-rama! may be included on the commercially available
CD-ROM of the archives.
[Archived as /info-mac/font/util/font-o-rama-111.hqx; 154K]
Date: Fri, 17 May 1996 03:15:26 -0700
Subject: [*] GifBuilder 0.3.2
GifBuilder 0.3.2 is a utility to create animated GIF files, which quickly
become a popular way to include short movies in Web pages. Its input is
an existing animated GIF, a bunch of PICT, GIF and/or TIFF files, or a
QuickTime movie, and its output is a GIF89a file with multiple images.
Options include color palette, pixel depth, interlacing, transparency,
interframe delay, disposal method, frame offset, looping and dithering.
Animations can be previewed. Comprehensive scripting support. Fat binary.
Main changes since 0.3.1: Frame size optimization (resulting often in
large file size savings), output depth of 3/5/6/7 bits/pixel, two more
cross-platform color palettes, basic online help, many user interface
improvments and bug fixes.
GifBuilder 0.3.2 is freeware (see the readme file for the details).
Yves Piguet
W3: http://iawww.epfl.ch/Staff/Yves.Piguet/Yves.Piguet.html
[Archived as /info-mac/gst/grf/gif-builder-032.hqx; 181K]
Date: Fri, 17 May 1996 03:15:25 -0700
Subject: [*] GifBuilder 0.3.2 (French)
[GifBuilder 0.3.2 F is the French version of GifBuilder 0.3.2, a freeware
utility to create animated GIF files.]
GifBuilder 0.3.2 F est un utilitaire pour creer des fichiers GIF animes,
qui permettent d'inclure de courtes animations dans des pages web. Il
accepte en entree des GIF animes existants, des fichiers PICT, GIF et/ou
TIFF ou des films QuickTime, et produit en sortie des fichiers GIF 89a
standard avec plusieurs images. Les options GIF standard sont supportees.
Les animations peuvent etre previsualisees. Largement scriptable. Natif
68k/PPC.
Changements depuis 0.3.1 F: optimisation de la taille des images (ce qui
permet d'obtenir des tailles de fichier tres reduites), profondeur de
3, 5, 6 ou 7 bits/pixel, deux palettes multi-plateformes de plus, aide
en ligne, beaucoup d'ameliorations de l'interface utilisateur et de bogues
en moins.
GifBuilder 0.3.2 F est un graticiel (cf. le fichier Lisez-Moi pour plus
de details).
Yves Piguet
[Archived as /info-mac/gst/grf/gif-builder-032-fr.hqx; 182K]
Date: Fri, 17 May 1996 03:16:17 -0700
Subject: [*] Insomniac 1.1.0 for PowerBooks
Keywords: POWERBOOK PORTABLE DUO SYSTEM SLEEP AWAKE MODEM
Note: This utility works only on those Macintosh models that can wake
themselves up (Macintosh Portable, PowerBook 100, PowerBook 500 & 5300
series, or PowerBook Duos).
Some PowerBooks have the ability to wake themselves up. This is very
convenient, for automatically sending faxes or email in the middle of
the night.
However, the "PowerBook" or "Portable" Control Panel provided by Apple
only allows you to enter a single wakeup time. This prevents you from
scheduling multiple wake-up sessions. For example, if you wanted to
send your faxes at 1:00am, and then download some files at 2:00am,
you'd have to stay up until 1:00am, and reset the wakeup timer
manually.
Insomniac allows you to program up to fifty wakeup "events" (registered
copies only). Therefore, you can have your PowerBook wake up several
times during the night, or even program it to wake up once a night for
weeks on end.
Version 1.1.0 contains the following enhancements:
* Converted to CodeWarrior and created PowerPC version.
* Added doubleclicking on entries to modify them.
* Fixed small memory leak that could cause crashes after extended use.
* Prevented unselecting entries by clicking beyond end of list.
* Repositions windows if they were positioned on a larger monitor.
Shareware; $10 registration fee suggested. Unregistered copies allow
you to enter up to two wake-up events.
[Archived as /info-mac/cfg/insomniac-110.hqx; 141K]
Date: Fri, 17 May 1996 03:16:04 -0700
Subject: [*] Log Watcher 1.0.0
Log Watcher is a program to help monitorize continuously log file generated
by Server.
If you run a WWW Server, a file server, even a bbs, any other kind of
software generating a log file, log watcher can help you.
Usually Server generate text file on disk reporting all operations and
activities.
Viewing these file require to open them using a text-processor.
The file is continuously updated and you have to re-open it to see fresh
data, usually this files are also big and open them requires seconds.
Log Watcher solve these problems.
- Runs on the server or on another Mac on a local network.
- Shows you always the last portion of the log file.
- Scrolls automatically to the bottom of the view.
- Brings to front the updated window.
- Reads only last portion of the file not in seconds, but in a fraction!
- All operations are performed automatically, without manual request.
- It Doesn't hog the CPU.
- All features are selectable & customizable.
Available both for 68K Mac and Power Mac
This is the 68k version
Roberto Panetta
[Archived as /info-mac/comm/inet/log-watcher-100.hqx; 284K]
Date: Fri, 17 May 1996 03:15:56 -0700
Subject: [*] MacTyping'French 3.4
MacTyping'French=81 by W. Rogers is an inexpensive Macintosh sharware progra=
m
that will help you learn to type in French or just improve your typing in
=46rench. The instructions are in English, the typing materials are in
=46rench.
While not a language tutor, the program will also help if your learning
=46rench, because you will use the French alphabet, type from among thousand=
s
of correctly-spelled French words, and type from among hundreds of
well-written French sentences.
The program uses five integrated work areas that together teach correct
finger placement and "touch-typing" memory of the keys on the keyboard.
Practice materials include: single letters, letter & number sequences,
words, sentences, paragraphs, and free typing. The program offers a
spelling checker, user-defined speed goals, score sheets, time tracking
with rest-signals, and many other helpful features. The program also comes
in English and English Dvorak. Other non-English versions (e.g., German,
Italian, Spanish) under development. Users can devise their own
session-routines, by working in one or more of the modules for ten to
fifteen minutes each.
W. Rogers
[email protected]
[Archived as /info-mac/edu/mac-typing-french-34.hqx; 178K]
Date: Sun, 19 May 1996 04:27:39 -0700
Subject: [*] Mercutio MDEF 1.3b9
This is a public beta of the Mercutio MDEF v1.3b9.
The Mercutio MDEF is a Menu DEFinition resource that allow developers
to easily and elegantly extend the power of their application menus.
These MDEFs allow menus to have multiple-modifier key-equivalents
(e.g. shift-command-C), custom icons, item callbacks, and other
goodies.
Major feature additions and changes since 1.2 are:
- Support for window font/size: Mercutio now correctly draws popup
menus in the current font and size. This means you can use Mercutio
for Geneva 9-pt popup menus and the like.
- Graphic icons for non-printing keys: non-printing key equivalents
such as page up/ down, home/help, etc. can be drawn as text or as
icons that look like the keys on the extended keyboard.
- Various cosmetic changes, optimizations and bug fixes.
- New software license -- please read as it defines the terms under
which you may use Mercutio.
As before, Mercutio includes:
- Support for non-printing keys (function keys, page up/down,
arrow keys, etc)
- Support for icon suites, small and large icons, and SICNs in
hierarchical menu items.
- Support for all 4 modifier keys (command, shift, option, control)
- User-definable style mapping: developer determines which style
bits are used as feature flags
- Dynamic items: items whose contents change depending on what
modifier keys are being held down (e.g. when the option key is
held down, Save becomes Save All).
- Application callback routine to let you decide on the fly what
the item contents should be.
- System 7's Balloon Help and True Gray.
- Color menus.
- 99% compatible with standard MDEF.
Mercutio is copyright (c) 1992-1996 by Ramon M. Felciano
Ramon Felciano
[email protected]
Digital Alchemy
[Archived as /info-mac/dev/mercutio-mdef-13b9.hqx; 887K]
Date: Fri, 17 May 1996 03:15:34 -0700
Subject: [*] Missions of the Reliant v2.0.0 -> v2.0.1 Patch
This patch upgrades Missions v2.0.0 to Missions v2.0.1
[Archived as /info-mac/game/arc/missions-of-rel-20-to-201.hqx; 22K]
Date: Fri, 17 May 1996 03:15:48 -0700
Subject: [*] Missions of the Reliant v2.0.1
Michael Rubin's Missions of the Reliant v2.0.1
[Archived as /info-mac/game/arc/missions-of-reliant-201.hqx; 2025K]
Date: Fri, 17 May 1996 03:16:19 -0700
Subject: [*] Mobius Speedster Fix 1.0
The Mobius Speedster series of Accelerator cards have a problem with
Apple's Sound Manager causing screeching noises whenever sounds are played
. This problem was previously corrected by replacing the Sound Manager
extension and Sound control panel of System 7.1.
System 7.5 eliminated the Sound Manager extension making the previous fix
unusable. I have studied the problem and come up with fixes to the sound
manager code located within the System files of System 7.5. Running these
patches will install the new fixes.
This archive includes patches for Systems 7.5, 7.5.1 and 7.5.3.
These patches do not allow the Speedster to use Virtual Memory, RamDoubler
nor Debugger (MacsBug).
Shareware: $5.00(US)
Anthony D. Saxton
[email protected]
Elenay Creations
[Archived as /info-mac/cfg/mobius-system-75x-sound-fix.hqx; 78K]
Date: Fri, 17 May 1996 03:15:32 -0700
Subject: [*] MOON EGG Version 1.0a1
Point Productions, Inc.
This is a stand-alone version of a Shockwave demo released by Point
Productions, Inc. Land the egg on target at five meters per second or
slower. Use the center button for retro rockets, left and right buttons to
navigate (or comma and period keys on the keyboard).
The program is an alpha-release-- sequels are planned, including a mini
space adventure. Check the Point Productions home page
(http://www.pointpro.com/pointpro) for the latest release information!
Designed & Programmed by Chip Buchanan
email: [email protected]
[Archived as /info-mac/game/moon-egg-10a1.hqx; 759K]
Date: Fri, 17 May 1996 03:16:12 -0700
Subject: [*] MYM2QIF 2.6
This is the latest version of the MYM converter. Version 4.6 removes
extra spaces from account and payee names.
MYM2QIF will convert Managing Your Money files to QIF files that you can
import into Quicken. You can convert checking, cash, credit card, and
portfolio accounts to QIF files.
There is a $10 shareware fee. You can only import approximately 30
transactions until you register the software. You can order the a disk a
printed documentation (simply double-click the icon to print the
invoice).
May be included on CD-ROMs
[Archived as /info-mac/cmp/mym-to-qif-46.hqx; 232K]
Date: Sun, 19 May 1996 04:27:27 -0700
Subject: [*] Skat 1.1.2
Enclosed is the newest shareware version of the popular card game, Skat.
It should replace Skat11.sea.hqx in your archive. This is the national
game of Germany and is played by 20 million enthusiasts worldwide. Bridge
players will enjoy the new challenge. Players of Euchre and Pinochle will
enjoy the step up. Includes beginners' guide and handbook.
J. Sell
[Archived as /info-mac/game/crd/skat-112.hqx; 953K]
Date: Fri, 17 May 1996 03:16:24 -0700
Subject: [*] Stereo "Zorvak Beep"
The "Zorvak Beep..." a stunning and dark sci-fi sound file, is another
unique System Alert Beep to add to your collection of Mac sounds. It is
a sudden blast of a futuristic siren that shreads from left to right and
back again as it tapers off.
The Zorvak Beep is available in both stereo 16-bit/44kHz and 8-bit/22kHz
versions and can be downloaded here or at the Clixsounds WWW site at
http://www.edmondsun.com/clix/ .
Instructions are included for installation as a system beep, and no extra
software is needed.
Clixsounds can be reached at:
Internet: [email protected]
America Online: CLIXSOUNDS
[Archived as /info-mac/art/snd/zorvak-8-bit.hqx; 194K]
[Archived as /info-mac/art/snd/zorvak-16-bit.hqx; 550K]
Date: Fri, 17 May 1996 03:15:51 -0700
Subject: [*] Sword Dream v1.7 US
The attached file contains a complete, fully functional copy of Sword
Dream, the fantasy role playing game for Macintosh. Version 1.7 is
accelerated for PowerPC and contains some bug fixes. For all details of the
changes in this version, or to download an updater that will upgrade
previous versions to v1.7, please check http://www.comenius.com/dream/
Luca Accomazzi
[Archived as /info-mac/game/adv/sword-dream-17.hqx; 958K]
Date: Fri, 17 May 1996 03:15:59 -0700
Subject: [*] TKS Creator List 4/30/96
Here's some new stuff from Teknosys for Mac Developers out there!
Sincerely,
Paul Cunningham
Product Development Manager
Teknosys, Inc.
[Archived as /info-mac/dev/tks-creator-list-4-30-96.hqx; 48K]
Date: Fri, 17 May 1996 03:16:02 -0700
Subject: [*] VersionEdit 2.0
Sincerely,
Paul Cunningham
Teknosys, Inc.
[Archived as /info-mac/dev/version-edit-20.hqx; 95K]
Date: Fri, 17 May 1996 03:16:22 -0700
Subject: [*] VIRTUAL 3D KALEIDOSCOPE 3.0.0
VIRTUAL 3D KALEIDOSCOPE 3.0.0.sit.hqx 5/1/96 3.0.0
This is a kaleidoscope simulation that also zooms the images into and
out of the screen. Sounds can be associated with the various
movements. You can import any picture you like to have it go through
the visual contortions. There are numerous settings to get some very
interesting effects.
[Archived as /info-mac/art/virtual-3d-kaleidoscope.hqx; 285K]
Date: Fri, 17 May 1996 03:15:49 -0700
Subject: [*] Wrath of the Aliens
Here is a new game I have finished programming, and I would like it on the
Info-Mac archive.
Thanks!
[Archived as /info-mac/game/arc/wrath-of-the-aliens.hqx; 454K]
Date: Fri, 17 May 1996 02:22:04 -0500
Subject: (A) Monitor getting hot
[email protected] (Keijiro Ikebe) asked:
> I have Apple Multiple Scan 15" Display and it gets real hot after I use it
> for a while. Is it normal for the monitors to get hot, or is there a
> problem with my monitor?
There should be something on the back of the monitor that says how many
watts it consumes. Most of that power gets converted into heat. If the
monitor produces no more heat than a light bulb of approximately the
same wattage, it's normal.
So far, no one has sold a gadget that lets you use this wasted energy to
keep your coffee warm. So far.
-- Tony ([email protected])
Date: Sat, 18 May 1996 09:20:21 -0700
Subject: (A) System 7.5.3 update replies
I got three kinds of replies to my query about the delay in shipment of the
System 7.5.3.
1) "I got mine right away; you should reorder."
2) "Mine took a month to arrive, in fact it got here yesterday."
3) You can get it for free with the June issue of MacUser if you buy it on
the newsstand.
Given #2, I'm going to wait a bit longer, since I am a MacUser subscriber
and would just as soon not shell out for another copy. Nobody sent me the
relevant phone number to check on the order.
Thanks for all your messages.
Paul Brians, Department of English,Washington State University
Pullman, WA 99164-5020
[email protected]
http://www.wsu.edu:8080/~brians
Date: Sun, 19 May 1996 08:30:40 -0700
Subject: (Q) Internet Assistant
At the suggestion of some folks here I downloaded Microsoft Internet
Assistant for Word 6.0.1 and tried it. The experience reminded me of why I
have kept using Word 5.1 months after having bought 6.01; but maybe I can
get used to it.
IA has potential, but to save me more work than it creates I would need to
be able to alter its translation table substantially. The documentation
that comes with the beta is very incomplete (it has links to documents not
supplied, for instance, with DOS naming conventions). The online tutorial
at Microsoft's Web site is for the Windows version, which is not a huge
problem (except for the first step), but it too is pretty sketchy. Does
anybody know if there is a way to alter IA's behavior short of ResEdit?
Is it just a coincidence that IA is the opposite of AI? :>)
[email protected]
Date: Sun, 19 May 1996 11:31:07 -0700
Subject: (Q)Removing Termination from drive?
Does anyone know where to get information (or how to) remove termination
>From a drive? I have an old internal drive that is terminated, and I want
to put it in an external case. Whenever I hook up the drive to the external
case and plug it in (I have a 6100/60, the only other devices on the SCSI
bus are a external CD drive and a Zip drive) the machine won't start up,
making me think that it has to do with termination.
Thanks in advance for your help! Please repsond to either the list or to
[email protected], since my regular account is changing...
-mike
Mike Sterling ([email protected])
http://www.redshift.com/~mike/
Quality Assurance
Casady & Greene, Inc.
Date: Fri, 17 May 1996 22:45:49 -0500
Subject: [Q] Netscape - can't "Save As..." Text
Hi -
Could some helpful soul tell me why I can no longer save any web pages
as text? Save As... source works okay, but if I select text in
the save dialog, a standard download window opens,and just sits there.
Cancel won't make it go away, and the document never gets saved (size of 0k).
I'm using 2.0.2 - I think it stopped working with 2.0.1.
Thanks in advance.
Date: Fri, 17 May 1996 21:25:51 +0200
Subject: [Q] Where's the new FreePPP?
At 10:30 PM -0300 5/15/96, Josmar Arruda said:
> Hello!
> Does anyone know if the new release of FreePPP already is out? The last was
> 2.5b4, but mine already expired, and I had to go back to 1.0.5
> I searched at Info-Mac and Apple sites, but nothing. Please, email me if
> you know where to get it.
> Thanks in advance,
> Josmar Arruda
> [email protected]
you can try "http://www.netmind.com/URL-minder/URL-minder.html"
you should have no problems with the new PP, I've had it for about a week
now, and it's great (more features than the beta)
Robert Guerra (PGP Public key available on key servers)
Email: mailto://[email protected]
Home Page: http://www.superb-e.com/PS/rguerra/
Date: Fri, 17 May 1996 19:42:33 -0700
Subject: Appleworks files
I have access to a Apple-GS and a 3.5in drive. Transfer them to that
and then use Apple file Exchange. You can buy a 3.5in drive for the
Apple 2e, maybe at a surplus store. You will need an adapter card to
go with that. I still think the best way is the Apple-Gs.
Clarisworks will translate Appleworks text, SS, and database files.
Date: Sun, 19 May 1996 11:10:33 -0700
Subject: Auto-restart after crash?
I'm looking for a tool to immediately restart an unattended machine that
has crashed or locked up. I searched the HyperArchive, but it came up with
nothing.
Does anyone know where I can find this? I remember seeing something like it
a _long_ time ago.
Aaron
Aaron Peckham
http://www.ns.net/~peckham
Date: Fri, 17 May 1996 01:04:09 -0400
Subject: CD-ROM 7.5.3 update overdue?
> Seems like a month has passed since I ordered the 7.5.3 update
> CD-ROM (snip) still hasn't arrived. Should I be worried?
I wouldn't worry, Paul. Here's the note I made when I ordered:
Ordered floppies - 5:18pm Apr 11th from Robert
Ord #9015860 (FREE!)
to ship Apr. 29
(5-7 working dys to delivery)
The package was in my mail today. Add a month to that "5-7 dys"
Date: Sat, 18 May 1996 04:23:16 -0400
Subject: commercial messages
Does anyone know how to post messages about a small, home-based business on
multiple, appropriate bulletin boards? It's not for myself, so please
don't blast me. I write a weekly column for a local, daily newspaper in
South Florida, and one of my readers wants to know. Thanks.
Lana Sumpter * [email protected]
Date: Sun, 19 May 1996 08:42:13 -0400
Subject: Commerical Eudora
Hi again everyone. Being a university student, I am currently using Eudora
1.5.1 on my Duo 230 because it is free for educational use. I utilize
email quite a bit, however, so I am considering purchasing the commercial
version so I can take advantage of its features. However, since I've never
actually *seen* it, I'd like to try at least a demo of it before I buy, to
see if the features will really benefit me. Is there such a demo? I tried
downloading the new 3.0 beta, but only to discover that you need to have
Eudora 2.x already for it to install.
Thank you as always,
Christopher Ursich
[email protected]
Date: Sat, 18 May 1996 06:00:28 -0500
Subject: Convert sound files to Mac sounds
Dear Folks,
I'm brand new to Inet; our entire family are musicians. My son has
downloaded several sounds with .wav extensions. Do you have any
utilities to allow us to play these sounds (and others we may download)?
We have a Macintosh Performa 6200CD with 16M RAM and a 1 Gig HD.
Any info you can give us will be extremely helpful.
Thank you for your time and volunteer service.
Sincerely,
Allan Mesko, Little Rock, AR
Date: Sat, 18 May 96 17:45:07 -0500
Subject: E-mailing dictations / voice mail
Dear Paul -
Regarding your recent message in the Info-Mac digest:
>I would love it if my e-mail program provided a button that would allow me
>to use my PowerBook's built in speaker to record a message. I would then
>e-address it traditionally, it would be sent as an encoded attatchment via
>internet e-mail and the receiving e-mail program would recognize it as
>encoded voice mail and put a "play" button in the text field of the new
>message so the receiver would be able to play the message. I know this
>would increase the bandwith demand of e-mail 10K fold but it would make
>sending critical short bursts of information so easy for me that I know I
>would use it.
>What is the easiest way to accomplish this with the current state of
>Macintosh (and also Wintel, Unix crossplatform compatible) technology? Is
>anyone aware of any projects?
QuickMail from CE Software has been able to do this for many years (since
Macs first had microphones, in fact, along about the time of the IIsi and
the LC.) You can reach 'em for a demo copy at 1-800-5-CESOFT.
QuickMail is a LAN mail package (AppleTalk) with gateways to just about
every e-mail system on the planet(Internet/SMTP/POP/UUCP, as well as AOL,
CompuServe, CIS, MCI Mail, scriptable text mail systems, corporate mail
systems, X.400, you name it, there's a gateway from QuickMail to it).
It's the e-mail system my company uses at work.
- Bill Davis
Date: Sun, 19 May 1996 11:28:06 -0700 (PDT)
Subject: IIe->Powermac data conversion
Subject: IIe -> Powermac data conversion
Stan Thiemann asked:
>I would appreciate your ideas on two phases of a data conversion challenge.
>The source files are Appleworks (mostly word processor) residing on an Apple
>IIe equipped with a 5-1/4 drive.The destination is Clarisworks or MS Word
>residing on a Powermac 6100. The two phases are 1. transfering the
>information >and 2. converting the file format.
Kurt Witowski replied:
>This can be done. The hardest part is getting the files onto a 3.5 diskette.
>After that, ClarisWorks will translate Appleworks files. The easiest way
>(Iknow of) to get the files onto a 3.5 diskette from an Apple II is to use a
Diskette
>drive called "UniDisk" by Apple. The hard part about this is going to be
finding
>one (a UniDisk drive, that is). I suggest trying a company called Sun
Remarketing.
There is a bit more to it than that. To use a 3.5 drive on the Apple IIe, you
need
not only the drive but also an interface card (drive controller) inthe IIe. The
diskette must be formatted in ProDOS. Then, when you move the diskette to
the Mac, you need to a translation program, like Apple File Exchange to copy
the files to the Mac properly. The best translator program I know of is
MacLink Plus, which can translate between Apple II, Macintosh and PC formats.
The source files can be from a great many different programs, as can the the
destination formats. For example, I translated an AppleWorks word processor
file to a WordPerfect (PC) file and lost none of the page layout formatting.
If you don't want to buy the 3.5 disk, and don't have a friend who can copy
files
for you, another option is to use a comm program on the IIe and transmit the
file to the Mac. You don't even need a modem, just an appropriate serial
cable.
Hope that helps.
Cyrus Roton
Date: Sun, 19 May 1996 11:51:55 -0400
Subject: Launcher limitation (Q)
Dear Digesters,
Apple's System 7.5.3 Launcher Control Panel will only show the top 40
alphabetical items in the Launcher Items folder in the System folder.
Does anyone know how to increase the number of visible items in the
launcher? Or is it time switch back to Square One or similar utility?
Thank you.
Sincerely,
[email protected]
Date: 19 May 1996 08:58:36 GMT
Subject: Monitor getting hot
Recently in comp.sys.mac.digest,
[email protected] (Keijiro Ikebe) (by way of
I have the same model monitor, and it also gets hot with use. Just make sure
the ventilation slots aren't blocked by things such as sleeping cats. (Yes,
my cat has discovered that's the warmest spot in the house, and it lets her
keep an eye on me since otherwise I ignore her when I'm working on the
computer.)
"You are in a twisty little maze of URL's, all different."
[email protected] (Peter Kappesser) http://web.syr.edu/~pjkappes/maze
Date: Thu, 16 May 96 21:42:07 -0600
Subject: Performa 5300CD & 6300CD
I want to buy a Power PC for community lab. I checked the price list and I
discovered that Performa 5300CD and Performa 6300CD have the same
specifications
and prices (CAN $2800); both have 16 Mg Ram, 1.2 GB, 100Mz speed, TV-Video
connection, etc. Can anybody tell me which one I should Buy?
Date: Sun, 19 May 1996 20:27:34 -0500
Subject: PowerBook Freeze
Dear Info-Mac subscriber,
A friend's PowerBook Duo 230 4/80 has a problem since he has installed
System 7.51 : when he tries to wake up his PB after sleeping, the PB
wakes
up but the screen becomes grey and the Mac freezes after 2-3 seconds.
The
PB must be restarted, and then he works well. It is not a conflict
between
INITS (I have disabled everything). I also cleaned the P-RAM without
succes. This problem didn't exist when the PB ran under system 7.1.
What's
the problem?
Please send me any comment about this !
Thank you very much,
Laurent Daloze [[email protected]]
Date: Sat, 18 May 1996 09:39:14 -0400
Subject: Spreadsheet (Q)
Dear Info-Mac Readers,
I'm looking for a good inexpensive spreadsheet. Anybody have any
experience with Keep it Simple or other inexpensive spreadsheet?
I would love a spreadsheet that can parse data using any delimiter.
Especially important is its ability to sort multiple column data either
by alphanumeric or numeric values.
In addition all the usual @ functions would be great (@SUM is especially
important, Average, running sums would be great). Of course
graphing capability of 2-d and Pie charts is a must.
One thing that is going to be hard to get is something to
convert my old Full Impact and PC Lotus 1-2-3 files into
the spreadsheet format. Does Keep it Simple have facility to do this?
Also is Keep it Simple PowerMac native, or at least compatible with the
PowerMac 7200? If the answer to any of these questions is no, who does
have all these capabilities, or which ones are missing from which
spreadsheet?
I don't want to spend more than $100. Excel has now increased in price
to $300 putting it way out of reach.
Thank you.
Sincerely,
[email protected]
Date: Sat, 18 May 1996 13:21:21 +0000
Subject: Zip vs EZ Drives
Hi to all Info-Mac fans!
Just thought I'd have my say on the recent questions regarding Zip vs EZ
drives.
I too had a Syquest 44Mb drive for a couple of years, and, though it worked
most of the time, I had the inevitable problems with cartridges not
mounting properly, having to restart my mac to get the icon to appear on
the desktop etc., so when I came to choose a new removeable drive, I had no
hesitation after reading the reports to go for a Zip, and I haven't
regretted it since. It's extremely user-friendly, slick, fast, reliable and
just FEELS so much better than the clunky old Syquests.
Hope this helps anyone thinking of purchasing a new drive, but remember -
this is only MY opinion!
Jeremy Lee
[email protected]
--Info-Mac-Digest--
