EasySwitcher
EasySwitcher
Download: http://archive.info-mac.org/cfg/easy-switcher.hqx
If you are tired of always moving the mouse to the upper right of the screen
to change between open files, or to hide open applications, EasySwitcher can
help. EasySwitcher allows for Macintosh users to have the one good feature
of Windows users (plus a few things you can't do on a Windows machine). By
pressing Control-Tab you will get a Dialog that shows all your applications
that are running (Icons). You can toggle through your applications to bring
that application to the front.
Easy Switcher doesn't stop there!
* EasySwitcher is NOT an Extension. Thus, it can be started and stopped
like an
application at anytime (without having to restart your machine).
* EasySwitcher 'Watches' what applications you are using, and keeps them
only a few key
strokes away. So that Switching between 2 applications is quick and
easy.
* EasySwitcher even has a hot key to Hide the front application. This helps
keep your
desktop clean from cluttered windows.
System Requirements:
* System 7.1 or Later.
