Reply-To: [email protected]
Subject: Info-Mac Digest V14 #92
To: info-mac-list
MIME-Version: 1.0
--Info-Mac-Digest
Info-Mac Digest Mon, 15 Apr 96 Volume 14 : Issue 92
1984
7.5.3 Auto on/off use in 7.1
[A] DOS to MAC/online banking
[A] How to bypass internal HD at startup?
[A] Seeking utility to make windows re-sizeable from all corners
[A] Stylewriter Engine??
[Q] 9600bps PB modems & Apple Express Modem problem
Anybody Remember MacPostit
CD-R Systems and Software
Digicom ARA Script?
earthlink.net
FREE MAC CLASSIFIEDS!
Info-Mac Digest V14 #89
Keyboard Menu
Mac Java Support
Macsbug (2 msgs)
Mail handler
My Mac, Issue 12 (an ezine for Mac users)
Open Transport 1.1
pb 520 color display?
Problems Connecting
Seeking utility to make windows re-sizeable from all corners (2 msgs)
SoftWindows and CD-ROM
System 7.1 incompatibilities?
System 7.5 Update and System 7.5.2 Update both?
Typing program
Untrashable folder
Video Capture Boards
Virtual Reality Headsets for Mac...
Gordon Watts, Liam Breck, Igor Livshits, Adam C. Engst
Files for inclusion:
and upload it to:
--Info-Mac-Digest
Content-Disposition: attachment; filename="Info-Mac Digest V14 #92"
Date: Wed, 10 Apr 1996 13:17:24 -0500 (CDT)
Subject: 1984
I was out of the room when the original mac ad aired in the
superbowl and I haven't seen it since. Does anyone know where I can find
it, or if there is a digital version out there somewhere? Thanks.
Kurt Ramsauer**[email protected]**http://www.nworks.com/Kurt_R/rams.htm
Date: Wed, 10 Apr 1996 10:26:33 -0400
Subject: 7.5.3 Auto on/off use in 7.1
Can the Auto on/off control panel in 7.5.3 be used in 7.1?
Are their any other utilities that would do this?
Scott
Date: Mon, 15 Apr 96 01:18:45 +0200
Subject: [A] DOS to MAC/online banking
>Date: Mon, 1 Apr 1996 16:31:42 -0600
>From: [email protected] (Lars Christian Jensen)
>Subject: (Q) DOS to MAC/online banking
>Dear Info-Mac fellows
>Does some of you have any experience with online banking in a
>DOS-environment using a Mac? Can I use TCP/PPP for connecting and then
>switch to DOS, or do I need special DOS-software also for connecting?
>Could you recommend a suitable software (commercial-/share-/free-) for
>running DOS on a Mac (my system: 840 AV, 7,1, Geoport - none DOS-card)
>Thanks for any help
I've set up several Mac users of different DOS online-banking packages.
In each case we used one of Insignia's SoftPC/SoftWindows PC-emulation
products. They're commercial products -- but you only need the most
utterly basic one for most online-banking packages, since all they
usually require is a 286-AT with a modem on COM1. I guess this should
work with GeoPort, though I should warn you that I haven't tried that
yet. It has worked fine with internal PowerBook modems and external
desktop modems. HTH.
-- Phil Hudson -- --
Date: Sat, 13 Apr 1996 11:09:49 -0500
Subject: [A] How to bypass internal HD at startup?
On Sun, 31 Mar 1996 17:18:03 -0500, [email protected] (Michael
Dreimiller) wrote:
[...snip...]
> I have an external hard drive with a System folder on it that I'd like
> to
> use to boot the SE/30 but the SE/30 insists on trying to boot off of
> it's
> internal hard drive. I *think* I remember reading somewhere that there
> was
> a key that you could hold down during startup to make a Mac ignore an
> internal hard disk for situations like I have. Does anyone know if this
> is
> true and what key it is that I should hold down?
Yes: hold down shift-option-command-delete until you see or hear the
external drive starting up, then release.
Once you're running successfully off the external, open the Startup Disk
control panel and set the remote as the startup disk. That way, you won't
have to repeat the key combination each time because the setting is
retained in parameter RAM [PRAM].
On each subsequent startup, the Mac will attempt to start off the external
first. If the external drive is not available, the SE/30 will then try to
start off the internal, but will forever first look for the external until
you reset the startup disk.
Hope this helps. Cheers!
Gib Henry
Date: Wed, 10 Apr 1996 11:30:13 -0700
Subject: [A] Seeking utility to make windows re-sizeable from all corners
>While asking for a utility which adds a Windows feature to the Mac may make
>me unpopular in some circles (say, the Northern and Southern Hemispheres
>:), there was at one time a Control Panel or WDEF which let you resize a
>window by dragging on any one of its corners, a` la Windows. Does anyone
>recall this utility, and where I might find it? Also, if it hasn't been
>updated in a while, is it System 7.5.3-compatible? Thanks!
I use the Stretch control panel. Works like a charm with 7.5.3. Windows
does have a few good features, but not many. It sure is easier to add
their features to our OS than vice-versa...
David [email protected]
Date: Mon, 15 Apr 96 01:18:34 +0200
Subject: [A] Stylewriter Engine??
>Date: Sun, 7 Apr 1996 18:17:15 -0500 (CDT)
>From: Matthew David Franz
>Subject: Stylewriter Engine??
>This may seem like a weird question, but somewhere I recall
>reading/hearing that the Stylewriters have Canon engines (BJ-200 etc.)
>and with the correct software driver(s) and cabling I might be able to run
>my Stylewriter II as a BubbleJet on my DOS/Linux box through the serial
>port.
>Has anybody heard anything of the sort or is this idea just plain goofy?
>Thanks,
>Matthew Franz ([email protected])
>Katherine Stinson Middle School
>San Antonio, TX
You can treat a Portable StyleWriter exactly as if it were a Canon BJ10ex
-- because that is what it is. This one is unique in that it has the same
PC-standard Centronics parallel-port interface as the Canon-badged
version of the same engine, and Mac users have to use a (supplied)
serial-to-parallel converter cable to drive it. I've done this (driving
it from a PC using a BJ10ex driver) and the results were acceptable, but
not as good as using a real BJ10ex.
StyleWriter II's etc. should in theory be drivable from PC's too, I
guess, i.e from a PC using a serial cable (probably wired as a null
modem) with a Mac connector (mini-DIN 8) at one end and a PC connector
(DB9 or DB25) at the other and the appropriate Canon driver selected on
the PC. I couldn't swear to it though.
Date: Sun, 14 Apr 1996 13:36:22 -0300
Subject: [Q] 9600bps PB modems & Apple Express Modem problem
Hello all,
A friend of mine has a PowerBook 160 with an internal 9600bps Prometheus
modem. We can't install Apple Express Modem, because the installer says
that "it doesn't work with this macintosh". Prometheus gave only a
communication package older than my grandmom (System 6 Age).
I was told that Prometheus was bought by another company. I would like to
know were to find them or the company that supports its products nowadays.
Also, I would like to know if there's another option but Apple Express
Modem, that seems doesn't work with 9600bps modems.
I'm trying to connect this mac to the Internet, using FreePPP 1.0.5. The
ConfigPPP Panel can't dial because it can't find the modem.
Thanks a lot!
Josmar Arruda
[email protected]
Date: Sat, 13 Apr 1996 19:18:44 -0400
Subject: Anybody Remember MacPostit
While getting my weekly dose of Dilbert on the Web I saw an ad for 3M about
demoing Postit notes for you computer; being a little curious I checked it
out. 3M is now offering a Demo of a new program written for them to let
you have Postit notes on you machine. I did not read much more since its a
Windows only piece of software ( and 2M download at that).
My query is however -- didn't 3M sue or at least threaten the author of
MacPostit a couple of years ago? Because of the copyright of Postit and
that they were planning a similar program?
Rant mode on
I'm just annoyed that a big company like 3m would let their legal
department go after some one with a nice little program (it nicer than
Stickies, but that just me thinking so), and then come out years later with
said program and simply ignore that group of people (Us) that they took a
program away from by not releasing a Mac version
Rant mode off
by the way I never got to pay a shareware fee for macpostit because the
author requested that everyone with a copy destroy it (this happened about
a week after I downloaded it). Does anyone remember who the author is? and
does he have any other shareware available. I feel the need to support this
person today, and maybe boycot (maybe just not buy for a while) 3M.
I'm done ranting now
I feel much better
Louis Mackey
Date: Wed, 10 Apr 1996 13:55:14 -0700
Subject: CD-R Systems and Software
I am about to purchase a CD-R system for a small service business
(multimedia production and archiving client material to CD's will be the
primary services). I am curious as to which systems and software would be
best suited for this. It will need to be able to make CD's for PCs and
Macs, although the CD-R will only be connected to a PowerMacintosh 8100.
I'm currently leaning toward the Yamaha 2x/4x mechanism, but I don't really
know which software package is best. I'd like comments on both the
mechanism and software choices. I'm looking for a low cost entry, it
doesn't need to be fast, but it does need to be flexible.
Bruce Carter, Boise State Univ., Boise, ID 83725 [email protected]
Date: 10 Apr 1996 09:39:37 -0600
Subject: Digicom ARA Script?
Hey Apple Remote Access Users!!!
I've got a friend that bought a Digicom Scout 28.8 V.34 Model 6500 modem for
his Performa 637CD. The problem has been finding a script that will work!
The computer was previously using an Infocom 14.4 modem. This worked fine,
and nothing's changed since then, so it's not the machine. By the way, he's
using Apple Remote Access Personal Server v.2.0.1. The only Digicom script
that we've been able to find is a "Digicom Scout+" script. Not only does this
one not work, but it's for a 14.4 V.32 modem. The Hayes scripts will not
work. Oddly enough, the only one we've gotten to work is a "USRobotics
Sportster" script, but then it will only give us a top connection speed of
9600 baud. We've called Digicom about this, and they plead ignorance saying
that the device was never manufactured with Apple in mind, so no script was
manufactured ... >:-Date: Sat, 06 Apr 1996 01:36:53 +0000
>From: Neil Kresal
>Subject: earthlink.net
>I would greatly appreciate feedback on this internet provider. I haven't had
>the best luck and want to know if maybe it's just me.
Note that Earthlink's *TotalAccess* dialup module does not yet support
OpenTransport. But staying with MacTCP 2.0.6 I've had excellent results.
Date: Sat, 13 Apr 1996 22:42:36 -0600
Subject: FREE MAC CLASSIFIEDS!
The Mac Classifieds is now up and offering free classified ads for
those who want to buy, sell, and trade Mac computers, hardware, software, etc.
Visit the Mac Classifieds today at http://www.muzik.com/mac
Date: Wed, 10 Apr 1996 16:52:13 -0400
Subject: Info-Mac Digest V14 #89
You might want to try Elastic Reality
Date: Sat, 13 Apr 1996 19:18:41 -0400
Subject: Keyboard Menu
In Info-Mac Digest #089 Luke Stein Wrote:
> Long, long ago, I (manually) patched System 7.1 on my IIcx with the effect
> of establishing a helpful "keyboard" menu. This menu allowed a choice of
> keyboard layouts, and set over by the balloon help menu (which, incidently,
> had a much nicer icon than the "Apple Guide" one"). Now that I have a PM
> 7200/90, with System 7.5.3 (yes, I wen with the overnight download of the
> patcher), I don't have it. Does anyone know whether there is a way to patch
> 7.5.3 the same way? And how do I do it? I would appreciate it.
I also like the Keyboard Menu. Its available on the "International"
versions of MacOS, but using ResEdit you can make you version an
International Version...
Directions borrowed from Voodoo Mac (Tips & Tricks with an attitude) by Kay
Yarborough Nelson page 50...
(usual disclaimer about Resedit and mucking with you System. Make a copy
first work only on the copy. Make sure you have a bootable floppy or
CD-ROM handy in case you mess up -- You mileage may vary)
On a copy of the System file open it up with ResEdit find the resource
named "itlc" (without the quotes) (it looks like a hand moving card two of
a three index card stack) open the itcl resource and find "Always show the
icon" its a radio button down a little ways. It should be reading "0"
right now since you don't have the flag icon showing. Change it to "1"
which it *true* close all windows; quit ResEdit; Move the Real (current)
System file out of the System Folder (put it some where save for a day or
so just in case) move you System Copy (the one you just edited) in to the
system folder rename it to System if necessary; Restart you Mac.
If all went well you should now have the flag (icon) of the keyboard
selected via the Keyboard CP in between the balloon help and finder menus.
By the way if you read this far this trick works at least from System 7.1
to 7.5.3.
Good luck
Work with a net
Louis Mackey
Date: Sat, 13 Apr 1996 18:21:19 +1000
Subject: Mac Java Support
I promised to summarise responses to my query as to why my Mac could access
Java - thanks to all those who put me straight; it was something basic
....... To quote Barry Campbell -
"The Macintosh version of Netscape (2.0x) does not yet support Java
applets. There *is* a Macintosh beta version with support for Java
applets... but,
alas, it only runs on Power Macs. Mac Netscape 2.0x DOES support
"JavaScript," but that's not real Java by a long shot..........."
Bob Lyon
Date: Sat, 13 Apr 1996 11:09:51 -0500
Subject: Macsbug
On Sat, 30 Mar 1996 22:13:31 -0500, [email protected] (Erik M.
Hjelle) wrote:
> I am curious as to what exactly Macsbug does. I've heard about from
> numerous places, but never what it does. If anyone could email any
> information, I would be very grateful.
The short answer: if you don't know what it is/does, you probably DON'T
want to mess with it.
The intermediate answer: It's intended for system and application
programmers to use during software development and debugging; it's NOT
intended for the end users of that software.
The long answer: It is a system-level, hexadecimal byte editor and program
debugger. It shows you screensful of hexadecimal digits and has a
command-line interface only an assembly-language programmer could love. It
can cause spectacular problems if misused, but can also show the internal
contents of registers and memory of your Mac which, in the hands of a
competent programmer, can pinpoint software bugs.
Hope one of these helps. Cheers,
Gib Henry
Date: Wed, 10 Apr 96 20:46:58 +0200
Subject: Macs Bug
>You've heard this many times by now, but for the doubting Thomases out
>there, here's another affidavit. Our Power Mac at work with newly-installed
>System 7.5.3 and long-ago-installed RAMDoubler 1.6.1 was randomly hanging
>ten to fifteen times a day. Force-Quitting and Command-Power-On-ing had no
>effect: the cursor just stopped moving and everything froze up. After
>installing MacsBug 6.5.3 this morning and rebooting, I went the rest of the
>day without a single glitch. Yee-hah!
What exactly does MacsBug do?
Kirk
Kirk McElhearn
Translations from French to English, English to French
Traductions francais-anglais, anglais-francais
[email protected]
http://www.lenet.fr/kirk
91 rue de la Mesangerie
37540 St Cyr sur Loire
France
Date: Sat, 13 Apr 1996 11:09:55 -0500
Subject: Mail handler
On Sat, 6 Apr 1996 22:15:02 -0500, [email protected] (Bill Ingraham) wrote:
> A friend who has a Performa 476 is disgusted with Eudora Light. Any time
> he trie to open his mail, the computer freezes. He has never been able
> to make it work from day one. It is probably not a problem with Eudora
> per se, but nothing has helped. Does anyone know of another mail handler
> that he can try?
First off, there are enough highly satisfied users of Eudora to suggest
that the problem clearly does not rest with Eudora. Most likely, it
results from hard-disk data corruption. Therefore, I recommend your friend
diagnose and fix the problem, since it can occur with any software,
including whatever he uses to replace Eudora.
First off, I'd try deleting the Eudora Settings file from System
Folder/Eudora Folder. Then, I'd run Norton Utilities, MacTools Pro, and
Disk First Aid repeatedly until all 3 report no errors. I'll bet that'll
eliminate the problem, and your friend will be a delighted Eudora user.
Gib Henry
Date: Sun, 14 Apr 1996 15:58:51 -0400 (EDT)
Subject: My Mac, Issue 12 (an ezine for Mac users)
My Mac is a free monthly electronic publication dedicated to ALL mac
users world wide. We try to bring the "everyday" experience to the readers,
and hope that our efforts bring a smile to your face, with the conviction
that Macintosh is the best computer there is. Subscriptions are free! Send
email with "Subscribe" in the body of the message to "[email protected]". Or
visit our WWW site at
My Mac Issue #12 (April 1996)
CONTENTS:
* Notes from the Editor - Tim Robertson, publisher
* eMail Page
* "Miner Thoughts" by Pete Miner
* "Open Doc" by Brian Koponen
* "The Waiting Game" by Brian Harniman
* "System 7.5.3 Review" by Adam Karneboge
* "Software Review" by Ed Khaja
(Address Master Pro 1.5, O-Limpia)
* "Software Review" by Tim Robertson
(Keywack 2.0, Windows 95 Patch, DiskTracker 1.0.2)
* "Hardware Review" by Adam Karneboge
(Macintosh Powerbook 5300c)
* "Hardware Review" by Evan McCarthy
(Global Village Powerport Platinum P.C.card Fax Modem)
* "The My Mac Interview"- by Russ Walkowich (Editor)
This Month's Special Guest is Guy Kawasaki,the Mac Evangelist
* "Internet Connection" by Evan McCarthy
(HTML Basics Part 1)
* "Wall Writings" by Mike Wallinga
(March Madness)
Tim Robertson, Publisher of My Mac, puts it this way about My Mac -
What to expect from My Mac? First, we want you to know that we are Mac
users just like you. We do not claim to know everything there is to know,
nor do we write a lot of high-end user columns. We leave that to Macworld,
MacUser, and MacSense. We are the everyday "Joe", who happen to write for
an electronic magazine. And our goal is simple: to let you know you are a
part of the Macintosh community.
Date: Sat, 13 Apr 1996 21:04:03 +0000
Subject: Open Transport 1.1
I am using it but wonder if I should be. I have just switched back to
Classic for the time being.
I am running on a ppc 6100/80 under System 7.5.3.
The system is somewhat stable if I run under FreePPP 1.0.5 & OT 1.1 but I
do get occasional crashes and dns errors.
If I move to the beta FreePPP 2.5b4, I get numerous crashes.
If I move to MacPPP 2.5, I get far fewer crashes, but numerous dns errors.
If I switch back to MacTCP, I miss the advantages of OT. But I am
forgetting, what are those advantages? Apple wants everyone to switch to
it, but will be providing a third approach in Copland. So, they advocate it
but will not be using it next year. So, why should we this year?
I guess I am missing something.
Stephen C. Camidge
[email protected]
RR #1, Desboro, Ontario N0H 1K0 Canada (519) 363-3912
Date: 10 Apr 1996 15:31:03 GMT
Subject: pb 520 color display?
A piece of software I'd like to run requires a 256 color monitor. I'm
using a (B/W) powerbook 520 with an external 256 color monitor. But the
software doesn't accept this. Anyone have any ideas about what I can do
to run the software?
Thanks
Leslie Burkholder
Date: Sat, 13 Apr 1996 21:23:40 -0500
Subject: Problems Connecting
I am on a 8500/120 16MB using a Teleport Platinum. I use OT 1.1 and System
7.5.3 with FreePPP 1.0.5.
I am having trouble connecting whenever the DarkSide of the Mac 4.2 is
running. I really don't know why. Sometimes all it takes is quitting the
program. Other times it takes a restart.
Any ideas??
Mike
Date: Wed, 10 Apr 1996 11:20:18 -0400
Subject: Seeking utility to make windows re-sizeable from all corners
On Wed, 10 Apr 1996 00:33:54 -0700, [email protected] (Mike Blackwell)
>make
There is (was?) something called "Stretch" at Info-Mac that did this, I
think. I haven't seen it in a while, so I can't vouch for any
compatibility. If you can't find it there anymore, let me know and I'll
see if I can dig it up.
HTH,
randy
Date: Wed, 10 Apr 1996 11:57:06 -0400
>Date: Wed, 10 Apr 1996 00:33:54 -0700
>From: [email protected] (Mike Blackwell)
There is a control panel called "eriks-windows-def..." or something like
that available in:
info-mac/gst/grf
I am running 7.5.3 and had no problems using this cdev, only a few
questioning glances from coworkers!
Doug
[email protected]
Date: Sat, 13 Apr 1996 17:43:43 -0400 (EDT)
Subject: SoftWindows and CD-ROM
Hi everybody. A question for SoftWindows users.
Here's the setup: PowerMac 7100/MacOS 7.5.3/Apple CD-ROM 600e
drive/Apple CD-ROM 5.1.2
And here's the question: If I install SoftWindows 1.02, will Windows
applications be able to access PC CD-ROMs in the Apple CD-ROM drive, or
do I need to install another CD-ROM driver?
TIA, Florin
Florin Neumann
[email protected]
Date: Wed, 10 Apr 1996 06:15:24 -0700
Subject: System 7.1 incompatibilities?
Hi-
Where do I get System 7 Pro if I already have System 7.1 can I get it as
an update? I am using a Macintosh LC and want to use certain applications
and extensions that are only compatible with the newer system software.
Please leave me a message here or send me E-Mail at [email protected] with any
ideas. Thanks for your help!
-Rob C.
* New Light Multimedia *
[email protected]
http://www.nworks.com/Rob/index.htm
Date: Sun, 14 Apr 1996 07:41:28 +0000
Subject: System 7.5 Update and System 7.5.2 Update both?
Do I need both files (System 7.5 Update and System 7.5.2 Update)?
I am running on a ppc 6100.
I have read over the documentation and come away with conflicting ideas.
The installer puts both in place, and each are 2.1 megs.
The former may be sufficient since I have the early ppc, but apparently the
fix to the sound manager is in the latter.
Stephen C. Camidge
[email protected]
Date: Sat, 13 Apr 1996 22:36:21 +0800
Subject: Typing program
I'm trying to learn the Dvorak keyboard. Could anyone recommend a good
typing program?
TIA,
Ariel
Date: Mon, 15 Apr 96 01:18:52 +0200
Subject: Untrashable folder
>I've an apparently empty folder in the trash.
[snip]
>Obviously it can just sit in the Trash forever - but
>does anyone know how I may remove it???
>Where do i go now?
A suggestion: try booting from some other disk (e.g. an Apple System
Software "Disk Tools" diskette, a Norton Emergency diskette, or another
HD with a system folder) and running Norton Disk Doctor or Apple's Disk
First Aid. This may fix it (or it may not). The trick is to be able to
unmount the disk, which you can't do if it's the startup disk. HTH.
Date: Wed, 10 Apr 1996 13:57:36 -0700
Subject: Video Capture Boards
I need to set up a Macintosh 8100/100 to do some video capture. I have an
Apple AV PDS card and a RasterOps 24STV NuBus card available, but I don't
have a great deal of time to do a bunch of testing. Does anyone know
offhand which of these cards would provide better performance? I'm
leaning toward the Apple card since it goes in the PDS, but I don't really
know. I do not have the MoviePak daughterboard for the 24STV and funds are
not available to purchase it.
Thanks for any information.
Date: Wed, 10 Apr 1996 18:55:36 +0200
(Andre' C. van der Ham))
Subject: Virtual Reality Headsets for Mac...
Do you have any information regarding the distribution of VR
Headsets that
work on Macintosh computers? If so I would greatly appreciate it.
-=Stargazer=-
--Info-Mac-Digest--
