Download: http://archive.info-mac.org/cfg/dxoft-get-info-102.hqx
DXoft Get Info 1.0.2
by DXoft
January 11th, 2000.
DXoft Get Info 1.0.2 has been released and is available at:
New in this version:
* the Registrations database now offers a choice of three layouts when
printing, from basic to detailed.
* Revised the documentation to include compatibility notes about FileMaker
Pro 5.
About DXoft Get Info:
DXoft Get Info is a collection of FileMaker Pro 3.0/4.0 relational databases
designed to let individual users track quickly and easily several key
information about their computer configuration, such as registration and
contact information about their software and hardware products, TCP/IP,
Remote Access, E-mail, News, FTP and Web page settings, "login" information
for those web sites that use a registration/subscription system etc.
Relying on the standard Internet Config system under both FileMaker Pro 3
and 4, DXoft Get Info is perfectly integrated with your other Internet
software.
DXoft Get Info is compatible with FileMaker Pro 5 once converted to the new
version's file format. The conversion happens automatically when one opens
DXoft Get Info using FileMaker Pro 5 or later.
DXoft Get Info is shareware and costs $20. A special offer is available to
Software & Hardware Tracker users, and DXoft Get Info users can upgrade to
Software & Hardware Tracker and Software & Hardware Tracker PRO for the same
price as Software & Hardware Tracker LITE users, thus saving $15.
Registrations are handled by Kagi Shareware.
Shareware is "try-before-you-buy" software: download DXoft Get Info and
evaluate it. Then, if you want to keep on using it beyond the 30-day trial
period, honor the shareware system and pay the registration fee. Otherwise,
just remove DXoft Get Info from your hard disk.
You need a copy of the FileMaker Pro application (version 3.0 or later) and
an Apple Macintosh computer to be able to use DXoft Get Info (while the
program may work with FileMaker Pro for Windows, it hasn't been tested and
is not supported under such configurations).
Thank you for supporting the shareware system!
DXoft Technical Support
