DoubleTouch 2.1.1E
DoubleTouch 2.1.1E
Post by Info-Mac » September 27th, 1999, 9:00 am
Download: http://archive.info-mac.org/cfg/double-touch-211-e.hqx
==Information==
Installing DoubleTouch, you can do window-shade
by pressing key twice (as double-click with mouse).
DoubleTouch has options.
One of option, Finder-option can collapse windows
in Finder when Finder's window aren't hilited.
In new version, in addition above function, Finder
-option hide other applications but Finder.
Using icon on desktop, it is very useful.
== Requirement ==
*Mac OS 8.5 or later (recommend)
*Mac OS 8/8.1
osato
mailto:[email protected]
http://www06.u-page.so-net.ne.jp/ga2/so ... index.html
