DocJet 1.3.2; Launcher utility.
Download: http://archive.info-mac.org/cfg/docjet-132-fat.hqx
DocJet is a wonderful utility for opening:
1) objects (files, applications, controls, folders, disks and so on),
2) groups of different objects by using specified applications,
3) specified kind of objects by using alternative applications,
4) specified kind of objects by using Internet Config's Post Process setting.
The first option works by means of keystrokes, the second through
dragging+keystrokes, the remaining by simple dragging. Naturally you may
also work from within DocJet, by using buttons.
You may create a data base containing all entries you need then remove all
aliases from desktop, leaving DocJet alone: it may supersede all af them!
DocJet is Internet Config, Drag Manager and Navigation Manager aware,
moreover it's Appearance savvy. It requires at least System 7 to run.
Author: Rocco Moliterno
mailto:[email protected]
http://yellowsoft.tsx.org/
DocJet page: http://www.geocities.com/SiliconValley/ ... ocjet.html
What's new in 1.3.2 version
- The list shows now all "Post process" applications.
- The list is now keyboard navigable.
- Better list font.
- Better memory partition.
- About box position saving.
- Moved "Post process" menu item.
- Code optimized for better performances.
- Improved Internet menu.
- Addresses update.
- Removed registration form from About Box.
- Added Registrations folder.
- Added Support folder.
