DisableForceQuit11
DisableForceQuit11
Download: http://archive.info-mac.org/cfg/disable ... uit-11.hqx
Disable Force Quit 1.1
Disable Force Quit Copyright © 1998 by John Montbriand.
All Rights Reserved.
A system extension allowing you to disable the force quit
command (command-option-escape) for selected application
programs.
With system 7.5.3 and later, the option of disabling the
power-off key is also provided. To allow for protected
access to the force quit command or power key, password
facilities have been provided.
System 7 on up...
see also,
__________________________
John Montbriand, P.O. Box. 1133, Saskatoon SK Canada, S7K 3N2
[email protected], (306) 955-5189.
