DesktopJanitor 1.0.2
Post by Info-Mac » March 26th, 1999, 11:00 am
Download: http://archive.info-mac.org/cfg/desktopjanitor-102.hqx
DesktopJanitor stores your desktop and restores its status, including
Desktop Theme, Window condition (status), Icon locations, Screen settings
(Height, Width, Depth), Application Switcher status.
This small utility also lets you assign several applications, scripts, and
documents for your convenience. you can keep your "particular" desktop
settings and change it as necessary.
