Desktop Cleaner 1.0
Desktop Cleaner 1.0
Post by Info-Mac » October 31st, 1998, 11:00 am
Download: http://archive.info-mac.org/cfg/desktop-cleaner-10.hqx
Desktop Cleaner maintains specified icons on the desktop and moves any other
unwanted icons to the trash. For example, some people like to have many
icons on there desktop all the time. Then they go on a downloading spree and
have a bunch of new files on the desktop afterward. Running Desktop Cleaner
will remove these additional and unwanted files. (Great for teachers, hence
the reason why it was written).
