DeskPicture is a handy utility that makes it easy for you to display
pictures on your desktop and manipulate them to your taste. Once you've
placed one or more pictures on your desktop, DeskPicture provides many
options for adjusting their appearance. In general, DeskPicture offers many
of the same functions for moving pictures and changing their size as drawing
applications, so if you've ever used that type of application, you should
have no problems working with DeskPicture.
