Delete Web Caches 2.6
Download: http://archive.info-mac.org/cfg/delete- ... hes-26.hqx
Delete Web Caches is a AppleScript text program that deletes a variety of
cache and other files from your hard disk. Cache files from using web
browsers can eat up a lot of hard drive free space in a very short time.
This update adds several improvements: It adds a routine to delete AOL
caches and it includes dialog boxes asking if you want to delete all web
caches and then if you want to empty the trash. The file is in text so
that you can change it until your heart's content. I've compiled it as a
run-only application and put it in my Apple Menu Items folder, and I use it
after every session on the web.
Buck Donham
Hilo, Hawaii
