Delete Now is a Contextual Menu Manager plugin for Mac OS 8, which allows
you to selectively delete files and folders from the Trash. Simply open
the Trash (for safety reasons, the items must already be in the Trash),
select the desired items, and choose Delete Now from the contextual menu.
Only the chosen items will be deleted.
