CustoFinder 7 F-1.2.4
Download: http://archive.info-mac.org/cfg/custo-f ... fr-124.hqx
Please find enclosed CustoFinder 7 1.2.4 French. This replace the version
1.2.3 French that might be already in the archive. It should go along
with version 1.2.4 US already available.
Abstract:
CustoFinder 7 is a small Control Panel that alters some option in System
7 and its Finder. It features:
-date format
-keyboard menu
-alias name style
-small icons on the desktop
This version brings System 7.6 compatibility.
CustoFinder 7 is $5 shareware
It is NOT compatible with MacOS 8 yet.
Thanks
Hub
Hubert Figuiere - [email protected] - BeOS / MacOS
http://www.teaser.fr/~hfiguiere - "May the Force be with you."
