Cursor-GreyScale
Cursor-GreyScale
Download: http://archive.info-mac.org/cfg/cursor-grey-scale.hqx
GreyScale is a system extension that replaces the standard arrow cursor
with a grey scale version. Takes up very little space, requires a color
macintosh.
-PETER J. Baird
Peter J. Baird
http://acs.bu.edu:8001/~baird
20 Oak Street
Belmont, MA 02178
(617) 489-1842
