CS Recorder 1.0 - CS Recorder is a freeware Control Strip module. It will allow
you to record and listen to sound messages, very easily. You can specify in the
preferences the recording quality. All messages are saved in a CS Recorder
messages folder based in your Preferences system folder. They are regular sound
system files, so you can also double click on it to listen them. It¹s completely
free. Have fun with CS Recorder. Email: [email protected] Site: http://perso.club-internet.fr/jeanpe/
