control-commander-fat-112
Download: http://archive.info-mac.org/cfg/control ... er-112.hqx
Control Commander is a utility that makes it simple to find
and change all those obscure Control Panel settings. It
creates a double-clickable list of everything that you can
do with CPanels on your Mac. A popup menu lets you limit the
list to categories like "Text", "Networks" or "Sounds".
Click on the list and go right to the CPanel you need !
You can also use it to create semi-automated files which can
help you make the CPanel settings needed for different purposes;
whether it's configuring your Mac for different Apps, setting
up multiple Macs in the same way, or crash recovery...
Comes with descriptions of over 150 CPanels. Runs on any Mac
that supports the "Appearance" extension (7.1 and up).
Support: http://members.aol.com/halfhill
