ColorSwitch_Pro_120
ColorSwitch_Pro_120
Download: http://archive.info-mac.org/cfg/colorswitch-pro-120.hqx
Keywords: COLORSWITCH PRO CONTROL STRIP PPP NETWORK SOUND MONITOR AUDIO
CD MENU CONTROL PANEL AMBROSIA OPEN TRANSPORT
Ambrosia Software, Inc. has just released ColorSwitch Pro 1.2.0, which
contains a number of bug fixes and adds a few features.
The following is a list of the bugs that were fixed and improvements that
were made in ColorSwitch Pro 1.2.0
-- New Module: Open Transport configuration selector.
-- Added support for "hidden" shortcuts.
-- Added playback controls to AudioCD module: normal, program, and
repeat.
-- Improved access speed when using AudioCD module.
-- Retooled submenu support for better compatibility.
-- Fixed cosmetic bug when using the MacOS 8 Appearance Manager.
-- Fixed PPP module to correctly find the installed PPP software on
non-English systems.
-- Fixed PPP module to correctly save window position, and better
algorithm for to cope with changing resolutions.
-- Fixed AudioCD module to correctly find the CD Remote preferences
on non-English systems.
-- Fixed conflict with PopupFolder when editing shortcuts.
-- Fixed grammar in Shortcuts module Balloon Help
-- Updated SDK to demonstrate how to create and manage submenus.
-- Updated reminder window and Register application to use new logo
that reflects the registered trademark.
-- Updated documentation to reflect new features.
