ClickLock! 1.0.1
ClickLock! 1.0.1
Download: http://archive.info-mac.org/cfg/clicklock-101.hqx
I've updated mouse utility, "ClickLock!" on Osato Utility Room.
This is its information.
*Title: ClickLock!
*Version: 1.0.1
*License: Shareware
*Developer: Osato Utility Room
*Developer e-mail: [email protected]
*Developer
URL: http://www06.u-page.so-net.ne.jp/ga2/so ... index.html
*Download
URLs: http://www06.u-page.so-net.ne.jp/ga2/so ... ware/Click
Lock!_1.0.1.sit
*UpdateInfo:
"ClickLock! CSM" is attached.
You can switch ClickLock! function with ControlStrip briefly.
*Description:
Using "ClickLock!", you can drag if releasing button while dragging.
***With standard one button mouse as attached Macintosh!***
You can use ClickLock! with 3 functions.
Press key while dragging, and you can drag if releasing button while
dragging.
DoubleClick and drag, and you can drag if releasing button while
dragging.
Shake cursor while dragging, and you can drag if releasing button while
dragging.
*Other minimum requirements:
PowerMacintosh
System7.6 or later
Standard mouse
