Download: http://archive.info-mac.org/cfg/sherloc ... gs.sit.hqx
Sherlock 2 plugs is an archive of two items for Mac OS. A folder entitled Internet Search Sites contains over 200 Shelock plug in scripts to perform the useful task of finding files, folders and packages, online. This allows for the swift location of online information independant of normal commercial ranking.
The scripts are present as independent plugs, simply drag the folder full of files into the System folder or copy individual items to you existing according to the droplet of your choice. Instructions on extending Sherlocks capacities are explained in the documentation file.
If you like these scripts, and wish more information about other creations please visit http://periander.50megs.com or http://neverthemac.i8.com/ or Email me [email protected]
David Christmass 2008
