Download: http://archive.info-mac.org/cfg/clean-i ... 153-jp.hqx
This is the Japanese version of the Clean-Install Assistant package.
Clean-Install Assistant makes it easier to migrate third-party and
personal items to a new Clean-Installed System Folder, and it may also be
used to:
*Save space and backup your valuable additions and preference files
only, instead of the whole System Folder.
*Install the same set of additions on multiple Macs.
*Remove extra files and folders from your System Folder to restore it
to a previous state: you can take a "snapshot" of the System Folder
and have Clean-Install Assistant extract any items added since.
v1.5.3 allows moving files from Mac OS 9.2.2 to a newer Mac OS version,
or to/from 9.2.2 and previous versions.
It is free for personal and educational use.
