SyncMate 1.4
Inter-computer communication software: Modem dialers, file transfer, telecommunications, etc.
SyncMate 1.4
Download: http://archive.info-mac.org/comm/syncmate14.dmg
From now on, synchronizing your Mac with Windows Mobile Pocket PC/Smartphone is as easy as one, two, three! SyncMate 1.4 is a new and very simple synchronization tool by Eltima Software.
SyncMate is offered in two editions: Free and Expert (available for a small fee).
SyncMate FREE Edition is a perfect solution for information management. It is FREE and easy-to-use synchronizer for Mac and Pocket PC/Smartphone, that will help you keep all your documents, text messages, contacts, calendar entries and events and other stuff well organized. With SyncMate Free edition you can synchronize applications like Address Book, iCal, etc. Also you can easily read SMS directly from your Mac, check detailed device information (battery state, etc) and visually analyze memory usage. You can download Free Edition right now!
SyncMate Expert Edition (available for a small fee) grants you even more synchronization possibilities. With Expert Edition it is very handy to synchronize time and share Internet between your Mac and your mobile device, which is very important for all mobile people. Synchronize iTunes and iPhoto to keep all your favorite music and pictures within a click of a button.
Expert Edition allows you to synchronize separate folders. Notes, and To Do’s synchronization is also available with SyncMate Expert Edition! You can view all the applications installed on PDA from your Mac.
Manage all text messages not even touching your Pocket PC! Send, receive, create and delete SMS when working at your Mac - that's what SyncMate Expert gives you. With SyncMate Expert Edition you can even sync your mail!
You can view the difference between these editions at comparison chart here: http://www.sync-mac.com/syncmate-expert.html
SyncMate installation is very easy. You do not have to unlock device in order to install SyncMate. Mac can be connected to mobile device via USB or Wi-Fi.
Platforms: Mac OS X 10.4 and higher, Mac OS X 10.5. Device compatibility: Windows Mobile Pocket 5, Windows Mobile Smartphone 5; Windows Mobile 6 Standard, Windows Mobile 6 Classic and Windows Mobile 6 Professional; Windows Mobile 6.1.
You can get detailed information or buy an Expert Edition at http://www.sync-mac.com/
