Chakaranda's Finder 8.6 patch adds usefull keystrokes to the MacOS 8.6
Finder, i.ex. "Command-T" for Empty Trash, and also keystrokes for
switching between views is added.
Feel free to redistribute the whole package in its original unmodified
form anywhere you like.
If included on CD-ROM you must send a copy of that to the address below.
Kind Regards
Chakaranda Hansen
Blaagaards Plads 6/2 th.
DK-2200 Copenhagen N.
Denmark
