CapsLight
CapsLight
Download: http://archive.info-mac.org/cfg/caps-light-10.hqx
CapsLight is a small control panel intended for PowerBook users,
although it will work on any Macintosh computer with System 7.0 or later.
CapsLight displays an icon in the menubar whenever the caps lock key is
engaged. On Powerbooks whose keyboards don't have a locking caps lock key
and have no caps lock light, this is a helpful feature.
Thanks for your help,
Alastair Matthews
