BeSpecific - for Mac OS enables application specific macros in
KeyQuencer. As you may know, once you assign a keystroke in
KeyQuencer, the keystroke does the same thing in all
applications. BeSpecific allows you to assign different tasks
to the same keystroke depending on what application is
current.
