Download: http://archive.info-mac.org/app/mac-at.hqx
MacAT is a Windows AT/UNIX cron task scheduling application for Macintosh server administrators. It is a fat binary application that allows 22 of the most common MacOS tasks to be run daily, weekly, monthly or yearly without user intervention.
These scheduled tasks include:
Launching Applications, Files and AppleScripts; Quitting individual applications or alternatively quitting all currently running processes; Rename and Delete any File or Folder; Hide and Show applications, Mount remote AppleShare volumes; Copy Files or Folders to mounted AppleTalk volumes; Unmount nominated AppleShare volumes; Restart or shutdown the Macintosh, and send eMail.
$39 Shareware from MacSOS, Australia
http://www.garvan.unsw.edu.au/gerham/macsos/
Cheers,
Dr Gerard Hammond
Garvan Institute of Medical Research
Create Like a God, Command Like a King, Work Like a Slave.
