Background Hider to watch TV on your Macintosh
Download: http://archive.info-mac.org/cfg/background-hider.hqx
If you can watch T-V directly on your Macintosh, this small program is for you. Normally, the image that can be used with Apple Video Player to get the best quality do not cover the whole screen, so the icons still can be seen in the background, which is distracting.
A fine solution is Background Hider, a small program which do not take a lot of memory. It can be used also for games or anything when you want to cover the desktop in black.
I am not the author, but it seems to be freeware.
Louis
Louis Bergeron C.P. 936 Rouyn Rouyn-Noranda Qc Canada J9X 5C8
Telephone-Phone (819) 764-3862 Telecopieur-Fax (819) 764-3758
