Download: http://archive.info-mac.org/cfg/autosave-101.hqx
Thank you for downloading and trying Auto-Save!
Safe guard your work with Auto-Save. Auto-Save is an easy to use application
which saves your work in virtually any Mac application at regular intervals.
You never have to worry about forgetting to click the Save command again.
Auto-Save lets you decide which applications should be told to save, how
often, and whether or not you should be asked before saving. Auto-Save also
allows you to assign scripts to applications for conditional saves and more.
Auto-Save does not add any system extensions to your hard disk.
