Austronaut Plugins for Sherlock
Post by Info-Mac » February 6th, 1999, 11:00 am
Download: http://archive.info-mac.org/cfg/austronaut-plugins.hqx
Here are two plugins for Apple's new Sherlock search program that comes
with Mac OS 8.5. It allows you to use Sherlock to search the Austrian WWW
directory "Austronaut", which is situated at http://www.austronaut.com/.
One plugin will only search for sites located in Austria, the other is
for worldwide searches (obviously you will only use one of them at a
time, as the worldwide plugin will also return all Austrian sites).
The plugins can be distributed freely and included on all non-profit
CD-ROMs.
This plugin and other software by my humble self can be downloaded from
http://aardvark.magnet.at/software/
To install, drag the "AustronautAustria.src" and "AustronautWorld.src"
files onto your System Folder icon. You will be asked if you want to put
it into your "Internet Search Sites" folder. Click "OK". That's it.
The files will update themselves automatically if newer versions become
available.
Regards,
