Austrian Patch for Mac OS D-8.1
Download: http://archive.info-mac.org/cfg/austria ... -osd81.hqx
This patch is similar to the one I posted earlier today. The other one
was for OS 8.5, this one patches the German version of Mac OS 8.1. It
adds some Austrian data to your system file, *replacing* the
corresponding German ones and thus compensating the lack of Austrian
localization resources in the Mac OS. You'll notice the difference in the
control panels Datum & Uhrzeit, Tastatureinstellungen and Zahlenformate,
plus, of course, in the keyboard menu.
This patch only works with the German version of Mac OS 8.1. Do not
attempt to install it over other versions.
Disclaimer
You use this software at your own risk. I have tested it and found it to
work fine, but there is no implicit or explicit warranty that it works.
If it damages your computer, if you lose any data, or if anything nasty
happens, I am not to be made responsible.
Freeware
This patch is absolutely free and may be distributed freely, as long as
no money is charged for it.
Contact
E-mail: [email protected]
WWW: http://aardvark.magnet.at/hp/
October 10th, 1998
