Austrian Keyboard Patch 2.0 for OS 8.5/8.6
Post by Info-Mac » August 3rd, 1999, 9:00 am
Download: http://archive.info-mac.org/cfg/austria ... tch-20.hqx
This is version 2.0 of the Austrian Keyboard Patch. It corrects a problem
in the German version of Mac OS 8.5, 8.5.1 and 8.6 where pressing the
Apostrophe key (') would produce an accent circonflexe [^] instead. With
the patch installed, the correct symbol is produced.
Version 2.0 adds compatibility with Mac OS 8.6 and makes better checks to
ensure that the correct system file is being patched.
System Requirements:
Any Apple Power Macintosh computer
Mac OS D-8.5, D-8.5.1 or D-8.6 (German version)
License:
Freeware
Standard disclaimer:
This software is provided as is, without warranty or promise of support.
Read the enclosed ReadMe before using it. In the unlikely event that this
software should cause any damage, the author of this patch cannot be made
responsible.
Contact information:
mailto:[email protected]
http://aardvark.magnet.at/software/
