Assimilator 2.0.1
Assimilator 2.0.1
Download: http://archive.info-mac.org/cfg/assimilator-201.hqx
Assimilator is designed for Macintosh lab situations where you want to make
all the harddisk's in a lab look almost identical. When the Assimilator
program is run on a lab Macintosh it will mount an AppleShare file server
and then make the harddisk look more or less exactly like a pre-specified
source folder on the server. It does this by throwing away (into the
Trash) any files or folders that don't belong or are different and
downloading any missing files. Icon positions, folder views, finder flags
and so forth are all corrected on the client Macintosh to match the source
folder.
Although it is designed for student lab situations, it has also proven
useful in other circumstances, such as for setting up newly purchased Macs
or in testing or demo labs.
New in version 2.0.1:
* Single log file on the system disk.
* Fixed problems with Alias resolution.
* Fixed the balloon help.
* Fixed import database to work with 1.x databases.
* Changed memory allocation in Assimilator.
* Various other minor changes and bug fixes.
New in version 2.0:
* Powerful new customization features.
* Handle multiple partitions.
* Restrict to portions of volumes.
* Support AppleShareIP over TCP/IP.
* Support assimilation from CD and local volumes.
* Execute protected scripts and applications.
* Fixed several bugs.
Assimilator requires System 7 and a harddisk.
Assimilator is shareware, $10 per Mac or $500 for a site license. Version
2.0 is a free upgrade if you registered on or after 1 Jan 1998, otherwise
the upgrade fee is 50%.
For more information, see our web site at .
Hope it proves useful,
Peter & Jeremy.
Assimilator v2.0.1 Copyright 1994-98 Peter N Lewis & Stairways Software
