AppearanceHopper 1.5
Download: http://archive.info-mac.org/cfg/appeara ... per-15.hqx
AppearanceHopper fills customization holes in the standard Mac OS 8.5, by
giving you access to features that are not editable from the Appearance
control panel. AppearanceHopper allows you to: set the font, size, and
style of the System Fonts; access the "hidden" scroll bar options; set the
style of alias names, and turn off the arrow badge on aliases; and modify
the Application Switcher palette, all in one user-friendly control panel.
AppearanceHopper is $9 shareware available in English and French; after
ten trials, you must register the software in order to continue using it.
Mac OS 8.5 and AppleScript are required.
For more information, visit Weedhopper Press at:
http://www.macinsearch.com/users/whpress/
