Application Switcher editor
Post by Info-Mac » December 4th, 1998, 11:00 am
Download: http://archive.info-mac.org/cfg/app-switcher-edit.hqx
This is the most powerful Appliaction Switcher editor you can find. It
let you edit everything in the Application Switcher, and then save your
work. It also gives you tips and let you change the scroll bar settings
more than the Appearance control panel.
Requires system 8.5 (or >) and Applescript.
Louis Chartrand
http://realbasic.8m.com
