Anyone out there purchase an iPhone 3G FM Transmitter/Charger? I bought the Belkin ClearCast, but it doesn't work well and I will be returning soon. I also tried a friends Monster transmitter, but that will not charge the iPhone 3G.
Any recommendations would be great, Thanks
Re: iPhone 3G FM Transmitter/Charger
It probably depends on your definition of working well. I never found any FM transmitter to be satisfactory, but that is my personal audio opinion.
The fcc limits the maximum signal strength of
fm transmitters so they are all destined to be crap.
Whenever a local radio station has a strong signal youll here that instead.
LG has a chocolate somthin phone w/ a transmitter / mp3 player that worked about
10 feet from the car but i didnt get to drive with away from the store so its hard to say. If you know an electrcal engineer or tech it should be easy
for them to ad a signal amplifier circuit to a cheap one.
they can get the parts at radio shack.
