Download: http://archive.info-mac.org/cfg/aliashelper.hqx
AliasHelper helps you manage aliases on your Mac by finding and displaying
all unattached aliases on your hard disk. AliasHelper then allows you to
easily reconnect or delete the unattached aliases. Optimized for MacOS 8 &
9.
Occasionally aliases lose their connection to the original file.
It's recommended to run AliasHelper a couple times a week to keep your
system optimized.
New for v1.1:
€ New Alias menu item: Suggestions. Offers suggestions for reconnecting the
alias.
€ New Alias menu item: Alias Info (also displayed when an alias in the list
is double-clicked).
€ Now able to select more than one alias in Alias list (send multiple
aliases to the Trash).
Bill Modesitt
[email protected]
Maui Software
www.mauisoftware.com
