Aladdin FlashBack 1.1.3
Download: http://archive.info-mac.org/cfg/aladdin ... ck-113.hqx
Requirements: System 7 (System 7.1.1 or higher for full drag-n-drop
capability)
License: Trialware, 30-day
Description: Ever overwritten a document by mistake and wished you could
get it back? Now you can with Aladdin FlashBack!
It's Simple To Use!
FlashBack allows you to recreate any document just as it was when it was saved.
Every time you save a FlashBack-protected file, you create a permanent record
that you can go back to any time you want. Now your ability to "undo" changes
is limited only by how often you save! Save as often as you like without falling
victim to "saver's remorse!"
Hey, we all make mistakes. FlashBack makes it painless to correct them. Get
FlashBack, and save your important work as often as you like without the worry
of accidentally saving over something you didn't mean to. Ever have a client
who never knows what they want, and then, out of the blue suddenly they do?
And it was that version you showed them three months ago? Now you can give it to
them, instantly. Because you've got it. Because you've got FlashBack.
