MacZip 1.00
MacZip 1.00
Post by Info-Mac » September 4th, 1998, 9:00 am
Download: http://archive.info-mac.org/cmp/zip-unz ... c-100b.hqx
I have just finished beta 5 of MacZip.
This is the new port of the fine Info-Zip's Zip and Unzip.
The GUI is very simple. It was not my intension to make a fullblown GUI,
however I think it's comfortable enough to use it as regular tool.
This port supports also Apple-event.So you can install it in your
WWW-Browser as a helper-app.
Binaries/Sources can be also found at:
http://www.sitec.net/maczip/download/
MacZip100b5C.hqx -> crypt version
MacZip100b5NC.hqx -> non crypt version
I think I'm very close to a final release of MacZip 1.00.
If you have any problems/questions don't hesitate
and send a email to me.
Most important / features are:
The complete set of macintosh finder-info is stored:
FXinfo, Mac-Pathname, file-dates and Finder-Comments
are now stored in the extra-field. Extra-field layout is
changed accordingly. Unzip uses now the filename stored in the
extra-field when unzipping.
Crypt-code added. It's now possible to encrypt/decrypt archives.
It's now possible to stop the run of Zip/Unzip with the well
known shortcut [Command] + [.]
System requirements:
* System 7
* any Macintosh
For more information visit my
Web page:
Homepage:
Cheers Dirk Haase
