Download: http://archive.info-mac.org/app/keypad-101.hqx
keypad 1.01 - do you have a hard time remembering all those
website passwords? Do you need a place to store important
bank or personal information? Do you need a place to store
those software registration codes? Then let Key Pad be your
electronic keyring. Key Pad is an easy to use application
designed to store all of your important information. Key Pad
is Internet Config savvy so you have one click access to all
of your password protected sites. Fast and compact, Key Pad
is a perfect choice for your Apple Menu. This update fixes a
bug, adds some preference options, and adds password
protection to data files.
