Leopard on Blue & White G3 w/G4 Upgrade?
I've read reports that people have had a surprisingly easy time getting Leopard to run on G4-upgrade PowerBook G3 Pismos, simply by installing leopard in FireWire Target Disk mode - no hacks or anything required. I am wondering if I can achieve the same thing on a Blue & White G3 upgraded with a 1ghz G4 from Sonnet, and a Radeon 9200 video card. Will this simply boot right into Leopard just like the Pismos do?
Has anyone tried such a thing, or know of any reports? Thanks...
Re: Leopard on Blue & White G3 w/G4 Upgrade?
You know, I've been wondering the same thing. I used to have a Blue & White Power Mac G3, which was my main computer for several years. Now they're getting so cheap on eBay and Craigs list, often in the $20 - $30 range. This might make a great secondary computer to my Mac Pro, especially if it can be made to run Leopard.
I am running tiger on my B&W at 700 mhz but i dont think leopard will work.
even if it could how slow would it be.
B&Ws can run Tiger even without G4 upgrades. Pismos also can run Tiger, but cannot run Leopard in G3 form. However, they can run Leopard with G4 upgrades as has been reported many times. I don't see why, then, a G3 B&W wouldn't be able to either?madmann wrote:I am running tiger on my B&W at 700 mhz but i dont think leopard will work
This topic intrigued me so much I went on Craig's List and now have two 400mhz B&W G3s to experiment with...
from looking on Low End Mac if you can get it working you will be the first one. http://lowendmac.com/osx/leopard/unsupported.html
well when does the b&w arrive.
I expect that the adb bus in the b&w may be part of the issue
has anyone have 10.5 running on a yikes g4 the only difference from it and a upgraded b&w would be the adb
just a thought
michael
just a thought
michael
It arrived about two weeks ago although I don't have a G4 processor for it yet, so it's still running Tiger as of this moment. And quite nicely might I say. I loaded it up with 640MB of memory and an ATI Radeon 7000 video card so it runs surprisingly well. Eventually I will buy a G4 for it and try Leopard.
I think that the problem is the PCI grapics and leopard needs AGP graphics, or at least that is what I have gotten from searching around the internet.madmann wrote:I expect that the adb bus in the b&w may be part of the issue
I forgot to mention that ADB busses were present in Macs until mid-way through the aluminum PowerBook G4 series.madmann wrote:I expect that the adb bus in the b&w may be part of the issue
dan keep us posted. My blue and white is waiting to know the results.
Once I go home for Summer break I'll be fiddling around with the G3s I've acquired. That won't be for a month yet.
