Stuffit Commands OSAX 5.5
Download: http://archive.info-mac.org/cmp/stuffIt ... sax-55.hqx
The StuffIt Commands OSAX is a scripting addition that adds to your
scripting system the ability to directly interact with the StuffIt Engine
from Aladdin Systems. The StuffIt Engine is included with almost all
commercial and shareware Aladdin products - check your Extensions folder.
If you don't have it, and wish to use this OSAX, download DropStuff
w/Expander Enhancer from the Aladdin web site
StuffIt Commands now supports all the new features of StuffIt 5.0 and later
versions, including new commands for Zipping as well as MacBinary and
UUencoding.
The author, Leonard Rosenthol, permits free distribution and use. Further
info available at his web site, www.lazerware.com.
John Rethorst
