Replace optical drive with HDD in Powerbook?
I've got a 12" powerbook with a dead optical drive, and I don't use it enough to be worth putting in a new optical drive. However, since I plan to upgrade it to Leopard it would be nice to have a second internal drive for time machine, so is it possible to put a hard drive in where the optical drive is?
Re: Replace optical drive with HDD in Powerbook?
I don't see a problem from a software standpoint. As for actually mounting a hard drive in place of the optical drive, there you may run into problems. It may not fit in the same space without major modification. I have not opened my 12" PowerBook to verify this, but I wish you luck if you attempt the operation.
Post pics if you get it to work.
Anything posted by me is not to be taken seriously.
As cool as the second drive would be, I'd be even happier if someone figured out how to lodge a second battery in there -- one that would be in the unit all the time, to supplement the user removable one. Go all Pismo on it, as it were.
