Download: http://archive.info-mac.org/cmp/mime-convert-107.hqx
A long overdue update to MIMEconvert.
The new version has two main changes
Version History
1.07
Added drag and drop to text window
Added Append to Same File command
You can now drag text files to the text field in MIMEconvert to llow for
quick and easy conversion. As well you can now repeatedly append data to
a file once you have already selected it with the Append command
What does it do?
MIMEconvert will:
remove MIME "mail" characters; the "+" and "&" symbols
convert hex encoded characters
save converted text to new files
append converted text to existing files
remove Submit, Reset or any other tag you specify
convert to tab delineated or any other form of single character
delineation
As usual MIMEconvert is free of charge
email: [email protected]
WWW: http://www.pixelgeek.com/
