mcvert-216.shar
mcvert-216.shar
Download: http://archive.info-mac.org/cmp/mailto-quickey-set.hqx
This mailto: information unscrambler for html-forms requires QuicKeys and
Tex-Edit Plus. With this QuicKey it is one keystroke simple to format and
unscramble the information returned by web page forms utilizing the
"mailto" html tag.
* Seeing Specially Graphics * http://www.awbbs.com/michaelz/
14-Oct-94 20:33:53-GMT,156634;000000000001
Return-Path: [email protected]
Received: from newsgw.mentorg.com (newsgw.mentorg.com [137.202.128.5]) by CAMIS.Stanford.EDU (8.6.8.1/8.6.5) with ESMTP id NAA27665 for ; Fri, 14 Oct 1994 13:33:36 -0700
Received: from wv.mentorg.com by newsgw.mentorg.com (8.6.4/CF5.22R)
id QAA01403; Fri, 14 Oct 1994 16:32:25 -0400
Received: from em-wv03.mentorg.com by wv.mentorg.com (8.6.8.1/CF5.22R)
id NAA15145; Fri, 14 Oct 1994 13:33:24 -0700
Received: from zigzag.MENTORG.COM by em-wv03.mentorg.com (8.6.8.1/CF5.19H)
id NAA15768; Fri, 14 Oct 1994 13:33:17 -0700
Received: by zigzag.MENTORG.COM (1.38.193.4/CF3.4)
id AA08296; Fri, 14 Oct 1994 13:33:14 -0700
Message-Id:
To: [email protected]
mcvert converts among Macintosh file formats used for file interchange,
including BinHex 4.0 (.hqx) and MacBinary (.bin). mcvert is written
in C and runs on many popular UNIX boxes. See mcvert.1/mcvert.man
(the man page) for program details. See README for how to build mcvert.
Please replace mcvert-215.shar with mcvert-216.shar, which follows.
Major changes are described below.
* Internal
* fix original bug of failing to convert lengths when extracting data
* and resource forks from MacBinary files -- thanks to Thomas Lange
* for finding and supplying the fix for this bug
* tidy up for Alpha OSF1 -- thanks to Holger Debelts
* for providing a fix for time()'s redeclaration
* check >
